[postgis-tickets] [PostGIS] #2685: Regress failures against 9.4 development branch
PostGIS trac at osgeo.org
Mon Apr 21 01:31:07 PDT 2014
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I think I have made 9.4 happy again.
 changed in r12482 and r12843 .  Someone should probably check I did the
 right thing since I had to remove one set of copies from regress.  I feel
 so dirty touching perl code :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2685#comment:3>
