[postgis-tickets] [PostGIS] #2714: [raster]: travis unhappy with raster changes
PostGIS trac at osgeo.org
Mon Apr 21 23:55:48 PDT 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
 Travis has been coughing up blood as of late.  Seems to have started with
 introduction of some gucs for raster.
 around here I would reckon:
 https://github.com/postgis/postgis/compare/98a3040c2d2f...e79b6ab3fba1
 Complaints:
 +ERROR:  unrecognized configuration parameter
 "postgis.gdal_enabled_drivers"
 ERROR: unrecognized configuration parameter "postgis.gdal_enabled_drivers"
 NOTICE: table "raster_outdb_template" does not exist, skipping
 DROP TABLE
 NOTICE: Invalid band index 1 for adding bands. Using band index 0
 ERROR: rt_util_gdal_open: Cannot open file. All GDAL drivers disabled
 travis is running:
 PostgreSQL 9.1.11 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
 Postgis 2.2.0dev - r12485 - 2014-04-21 13:14:17
 scripts 2.2.0dev r12485
 raster scripts 2.2.0dev r12485
 GEOS: 3.3.8-CAPI-1.7.8
 PROJ: Rel. 4.8.0, 6 March 2012
 GDAL: GDAL 1.9.2, released 2012/10/08
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2714>
