[postgis-tickets] [PostGIS] #2709: Crash (more often under high loads)
PostGIS trac at osgeo.org
Tue Apr 22 06:03:38 PDT 2014
 Reporter:  bshankle  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  PostGIS 2.1.3
Component:  postgis   |     Version:  2.1.x
 Keywords:            |
Changes (by robe):
 * cc: bshankle (added)
Comment:
 Bruce,
 Sorry haven't had a chance to look at this. A link to the natural earth
 file you are using would be helpful.  Ideally we prefer smaller tests we
 can easily fit in our regress suite if you can generate such a thing by
 isolating an offending geometry.
  As far as debugging -- check out the following (they are both a bit dated
 sorry)
 http://trac.osgeo.org/postgis/wiki/DevWikiGettingABackTrace
 This one is a bit dated but may be of use:
 http://blog.cleverelephant.ca/2008/08/valgrinding-postgis.html
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2709#comment:1>
