[postgis-tickets] [PostGIS] #2623: pgsql2shp creates a dbf with 0 records when the table only has a geometry column
PostGIS trac at osgeo.org
Tue Apr 29 04:46:51 PDT 2014
column
 Reporter:  winkey   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by landry):
 hexdump of the empty dbf for the source shapefile
 0000000 7203 1802 0004 0000 0021 0001 0000 0000
 0000010 0000 0000 0000 0000 0000 0000 0300 0000
 0000020 200d 2020 0020
 0000025
 full pgsql2shp command:
 pgsql2shp -r -f armoire_43 -h services -u postgis postgis "select t.* from
 erdf_armoires_simples_hta_2014 as t, communes_2154 as c where
 st_intersects(t.the_geom,c.the_geom) and c.insee_dept='43'"
 Preparing table for user query... Done.
 Initializing... Done (postgis major version: 1).
 Output shape: Point
 Dumping: XX [1 rows].
 hexdump of the empty dbf file generated by the command
 0000000 5f03 1a07 0001 0000 0041 000c 0000 0000
 0000010 0000 0000 0000 0000 0000 0000 0000 0000
 0000020 4947 0044 0000 0000 0000 4e00 0000 0000
 0000030 000b 0000 0000 0000 0000 0000 0000 0000
 0000040 200d 2032 2020 2020 2020 2020 0020
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2623#comment:4>
