[postgis-tickets] [PostGIS] #2723: failure to build against external json-c 0.12
PostGIS trac at osgeo.org
Wed Apr 30 14:39:13 PDT 2014
 Reporter:  landry   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 Similar to http://trac.osgeo.org/gdal/ticket/5449, postgis as is fails to
 build against json-c 0.12 since they removed the extern
 json_tokener_errors array, deprecated in favor of
 json_tokener_error_desc() present since 0.10.
 I've fixed it locally using http://www.openbsd.org/cgi-
 bin/cvsweb/ports/geo/postgis/patches/patch-
 liblwgeom_lwin_geojson_c?rev=1.1 but maybe a better fix could be commited
 upstream, depending if we want to require json 0.10 or still want to
 support older versions.
 I can provide a patch if needed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2723>
