[postgis-tickets] [PostGIS] #2870: Binary insert into geography column results in value being inserted as geometry.
PostGIS trac at osgeo.org
Sat Aug 2 09:09:34 PDT 2014
geometry.
 Reporter:  andrewdone  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by pramsey):
 You're seeing an error in the metadata, everything about the object should
 still be OK, so your library is going to be OK. I will fix the bug though.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2870#comment:2>
