[postgis-tickets] [PostGIS] #2872: make install builds documentation
PostGIS trac at osgeo.org
Thu Aug 7 05:07:34 PDT 2014
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by gdt):
 I found a bug.  In GNUMakefile.in, it checks for $(XSLTPROC).  But this is
 never set.  It should be @XSLTPROPC@, so that it is substituted.  Or there
 should be XSLTPROC=@XSLTPROC@ above.
 I also don't understand why comments are in the doc directory, since they
 seem to be something different.
 Also, if this wrapping stays, the install target should have the same
 wrapping of ifdef @XSLTPROC at .
 (And, I don't really understand why docs is a separate build target, or
 rather why the all: target doesn't include it.  The straightforward case
 is to have all the build dependencies and to just run make && make
 install.   I can certainly see having a code-only target for people
 without docbook, but that seems like an exceptional situation rather than
 normal.)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872#comment:8>
