[postgis-tickets] [PostGIS] #2879: cu_surface warnings
PostGIS trac at osgeo.org
Thu Aug 7 16:50:53 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 cu_surface.c
 cu_surface.c: In function 'polyhedralsurface_parse':
 cu_surface.c:316:6: warning: pointer targets in assignment differ in
 signedness [-Wpointer-sign]
   tmp = lwgeom_to_wkb(geom, WKB_HEX | WKB_ISO | WKB_NDR, 0);
 cu_surface.c: At top level:
 cu_surface.c:15:13: warning: 'check_tgeom' declared 'static' but never
 defined [-Wunused-function]
  static void check_tgeom(char *ewkt, int type, uint32_t srid, int
 is_solid);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2879>
