[postgis-tickets] [PostGIS] #2790: SET_VARSIZE redefined
PostGIS trac at osgeo.org
Thu Aug 7 18:22:21 PDT 2014
  Reporter:  robe    |       Owner:  colivier
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.2.0
 Component:  sfcgal  |     Version:  trunk
Resolution:          |    Keywords:  history
Comment(by robe):
 patch at r12873 should do the trick once and for all.  I removed all the
 legacy junk in pgsql_compat.h which references < 83.  8.2 is definitely
 not going to be supported for 2.2.  I also removed assert because
 technically it should have been included via liblwgeom_internal.h.
 liblwgeom_internal.h does have reference to postgis_config.h (before
 include of liblwgeom.h) so how this warning still happened after my last
 change is a bit disconcerting since it should have registered as 94 and
 not fallen into the 8.2 trap.
 Will close once confirmed winnie is no longer registering the warning.
 (don't have debbie set to test sfcgal yet so no warning on her to check).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2790#comment:7>
