[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
PostGIS trac at osgeo.org
Sun Aug 10 09:00:51 PDT 2014
  Reporter:  robe     |       Owner:  nicklas
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by nicklas):
 Yes, I guess you are right.
 The reason for moving the functions into the header file was that I saw a
 performance regression when they were in a separate file compared to when
 they were in the lwout_twkb.c file.
 The timing on a known data set and query, went from in average about 2850
 ms to above 3000 ms. I recompiled and tested back and forward a few times.
 So it is about 5%.
 When putting the functions into the header the timings was almost back
 where we began.
 But I think I will have to rewind to the version Sandro wrote with the
 functions in a varint.c file and take the performance impact.
 This is clearly a grey zone where the compilers doesn't fully agree. I
 guess it can be some setting in the config file that gives this
 difference?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:14>
