[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
PostGIS trac at osgeo.org
Sun Aug 10 09:26:06 PDT 2014
  Reporter:  robe     |       Owner:  nicklas
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by nicklas):
 The data set I am testing on is 171 mb. I will try to catch the effect in
 a smaller scale or from generating the numbers.
 I also think that the differnce is actually bigger because what I am doing
 is writing all geometries from the data set to a new table. So, some of
 the 3000 ms is just disc writing and unchanged between the two cases.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:16>
