[postgis-tickets] [PostGIS] #2908: Cannot upgrade: cannot drop function st_summarystats(raster, integer, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Tue Aug 26 07:31:46 PDT 2014
st_summarystats(raster,integer,boolean) because other objects depend on it
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:  raster                 |
Comment(by strk):
 These two lines are found in rtpostgis_upgrade_cleanup.sql:
 -- remove TYPE summarystats
 DROP FUNCTION IF EXISTS st_summarystats(raster,int, boolean);
 The datatype was removed as part of #1939
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2908#comment:1>
