[postgis-tickets] [PostGIS] #2910: Implement function to output Mapox Vector Tiles
PostGIS trac at osgeo.org
Wed Aug 27 08:09:22 PDT 2014
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Code for an ST_AsVectorTile_Geometry is being under development here:
 https://github.com/strk/postgis/tree/mvt
 The function it its current incarnation takes the coordinate of origin,
 the size of an output unit in source units (x and y), an optional
 tolerance (unused) and an optional clipping extent (unused).
 I'm thinking I should further simplify the interface by dropping the
 unused ones (tolerance and clipping).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2910#comment:2>
