[postgis-tickets] [PostGIS] #2247: [raster] Create ST_CreateOverviews()
PostGIS trac at osgeo.org
Fri Aug 29 06:51:01 PDT 2014
 Reporter:  dzwarg             |       Owner:  dzwarg
     Type:  enhancement        |      Status:  new
 Priority:  medium             |   Milestone:  PostGIS 2.2.0
Component:  raster             |     Version:  trunk
 Keywords:  raster, overviews  |
Comment(by strk):
 Pierre, the current version of the function I wrote produces the so-called
 "virtual grid" internally, so doesn't need any ST_MakeEmptyCoverage. Take
 a look here: https://github.com/strk/postgis/tree/svn-trunk-
 createoverviews
 The problem is in the interface itself. If the function takes table name,
 field name and scale factor, it won't be able to compute the target grid
 configuration unles the input coverage has a constant scale (for example).
 Maybe we should move the discussion on the list...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2247#comment:15>
