[postgis-tickets] [PostGIS] #2627: st_linetocurve() pta_desegmentize needs implementation for npoints < 4
PostGIS trac at osgeo.org
Wed Feb 5 00:40:08 PST 2014
 Reporter:  mjurce       |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.5
Component:  postgis      |     Version:  2.0.x
 Keywords:  curves       |
Changes (by strk):
  * type:  defect => enhancement
Comment:
 pramsey: yes, I think it would be a cast, but the function should only
 "cast" if a set of preconditions hold: approximate equidistance from the
 center, arc length matching the default number of quadrant segments (for 3
 points, with default quadrant segments being 8, the arc should cover not
 more than 3/8 of the quadrant). See also #2428.
 Changing to "enhancement".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2627#comment:6>
