[postgis-tickets] [PostGIS] #2637: ST_Area regress between 2.1.2 and 2.0.4 when using use_spheroid = false
PostGIS trac at osgeo.org
Wed Feb 5 21:13:20 PST 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 More funkiness with use_spheroid:
 SELECT gid, ST_Area(geog, false) As sphere_area, ST_Area(geog,true) AS
 spheroid_area
 FROM (VALUES (1, ST_GeogFromText('MULTIPOLYGON(((-71.0821 42.3036,-71.0822
 42.3036,-71.082 42.3038,-71.0819 42.3037,-71.0821 42.3036)))') ),
         (2, ST_GeogFromText('MULTIPOLYGON(((-71.1261 42.2703,-71.1257
 42.2703,-71.1257 42.2701,-71.126 42.2701,-71.1261 42.2702,-71.1261
 42.2703)))') ) ) As g(gid, geog)  ;
 In POSTGIS="2.0.4" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6 March
 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" (core procs from "2.0.4" need upgrade) RASTER (raster
 procs from "2.0.4" need upgrade) PostgreSQL 9.2.4, compiled by Visual C++
 build 1600, 32-bit
  gid |   sphere_area    |  spheroid_area
    1 |  228.61314662168 | 228.977274222299
    2 | 686.203767227692 | 687.292930366744
 In POSTGIS="2.1.2dev r12220" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build
 1600, 32-bit
    1 | 228.671128069666 | 228.977274222299
    2 | 686.211664392567 | 687.292930366744
 (2 rows)
 Note how the spheroid areas between two versions agree but the sphere
 areas do not.  Did we change our sphere between 2.0 and 2.1?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2637>
