[postgis-tickets] [PostGIS] #2627: st_linetocurve() pta_desegmentize needs implementation for npoints < 4
PostGIS trac at osgeo.org
Sun Feb 9 01:55:36 PST 2014
 Reporter:  mjurce       |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.5
Component:  postgis      |     Version:  2.0.x
 Keywords:  curves       |
Comment(by mjurce):
 Replying to [comment:8 mjurce]:
 > What about http://trac.osgeo.org/postgis/ticket/2464
 > The error parameter could be the max distance between the segment and
 the arc:
 > build the arc then check the distance against the linear segment.
 > Cast to arc if distance low ( to be specified ).
 This could be down with sagitta.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2627#comment:9>
