[postgis-tickets] [PostGIS] #2626: Targeting to publish postgis and jts parser relases to Central maven repository
PostGIS trac at osgeo.org
Sat Feb 15 23:38:32 PST 2014
repository
 Reporter:  bergun                    |       Owner:  bergun
     Type:  enhancement               |      Status:  new
 Priority:  medium                    |   Milestone:  PostGIS 2.1.2
Component:  java                      |     Version:  2.1.x
 Keywords:  Central maven repository  |
Comment(by bergun):
 See
 [WARNING] 'version' contains an expression but should be a constant. @
 org.postgis:postgis-
 jdbc:${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION},
 /storage/software/postgis/postgis/java/jdbc/pom.xml
 and also
 [WARNING] It is highly recommended to fix these problems because they
 threaten the stability of your build.
 [WARNING]
 [WARNING] For this reason, future Maven versions might no longer support
 building such malformed projects.
 I will try to find a best practice on version number management during
 release on pom.xml.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2626#comment:6>
