[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
PostGIS trac at osgeo.org
Sat Feb 22 08:41:18 PST 2014
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 as of r12245 postgis_proc_upgrade.pl will read "last_updated" information
 from the SQL itself (at least for aggregates) and will print a warning to
 stderr if that information is missing.
 It currently checks for "Availability" or "Changed". Ideally we'd add
 another label because "Changed" is also sometimes used for semantic change
 with no change in signature definition...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:17>
