[postgis-tickets] [PostGIS] #2648: Missing schema name in ST_GetFaceGeometry function call to topology table
PostGIS trac at osgeo.org
Sat Feb 22 23:31:54 PST 2014
  Reporter:  pauldzy   |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.1.2
 Component:  topology  |     Version:  2.1.x
Resolution:  fixed     |    Keywords:  history
Comment(by robe):
 Paul,
 The search_path to topology should be automatically added to database
 search_path when you install topology as part of the install process.  The
 cases I have seen where people have issues is if there user account has
 its own custom search path which overrides the database search_path.
 strk,
 Aren't there a lot of calls within functions that aren't schema qualified?
 e.g. AsTopoJSON makes calls to GetTopoGeomElements without schema
 qualification. topogeo_addPoint makes calls to ST_ChangeEdgeGeom without
 schema qualification. topogeo_addpolygon makes calls to ST_GetFaceGeometry
 without schema qualification.
 I can go on and on. But you get the point that topology doesn't currently
 work unless you have topology in your search_path.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2648#comment:5>
