[postgis-tickets] [PostGIS] #2651: tickets.sql: function st_envelope(unknown) is not unique
PostGIS trac at osgeo.org
Sun Feb 23 08:06:01 PST 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 When running regress/run_test.pl --extension regress/tickets.sql, 2 errors
 are raised about non-unique functions taking "unknown" type.
 This does NOT happen with non-extension install.
 I suspect it has to do with CASTs not being installed by the extension
 mechanism.
 NOTE: this should have nothing to do with the regression in extension
 upgrade (#2560), as it's not happening after upgrade but after initial
 install.
 Robe, can you confirm with any of your 2.1.x installs ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2651>
