[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
PostGIS trac at osgeo.org
Sun Feb 23 08:35:46 PST 2014
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 So for the record, as of r12261 in trunk and r12264 in 2.1 branch you can
 now use --extension --upgrade switches of run_test.pl to test both install
 and micro-upgrade using extension. Of course you need to "make install"
 first for that to work.
 You can run the whole testsuite, after make install, with:
 make check RUNTESTFLAGS='-v --extension --upgrade'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:28>
