[postgis-tickets] [PostGIS] #2594: travis failing with undefined palloc
PostGIS trac at osgeo.org
Fri Jan 3 20:12:55 PST 2014
 Reporter:  robe       |       Owner:  dustymugs
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.2
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
Comment(by robe):
 Since 2.1 is failing as well with same error, I don't think it has
 anything to do with Nathan's patch. Before that were a sequence of stopped
 builds -- e.g. https://travis-ci.org/postgis/postgis/builds/15493162
 which seems like issues with ubuntugis unstable.
 So I suspect might be an issue upstream.   Reminds me I should get back
 with Getty to use his scripts that build custom geos/gdal and maybe just
 pull postgresql from apt.postgresql.org.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2594#comment:4>
