[postgis-tickets] [PostGIS] #2586: [raster] ST_Clip with geometry smaller than pixel size
PostGIS trac at osgeo.org
Sun Jan 5 08:44:48 PST 2014
 Reporter:  dustymugs  |       Owner:  dustymugs
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.2
Component:  raster     |     Version:  2.1.x
 Keywords:             |
Comment(by dustymugs):
 This occurs with a geometry that is sufficiently smaller than the pixel
 ST_Multi(ST_Buffer('SRID=910001;POINT(624772 1534404)', 10))
 The following geometry works.
 ST_Multi(ST_Buffer('SRID=910001;POINT(624772 1534404)', 85))
 WITH foo AS (
         SELECT ST_Multi(ST_Buffer('SRID=910001;POINT(624772 1534404)',
 80)) AS geom
 SELECT
         ST_DumpValues(ST_Clip(r.rast, foo.geom))
 FROM test_raster r
 JOIN foo
         ON ST_Intersects(r.rast, foo.geom)
 The test raster was loaded with the following. The SRID is something user-
 specified for the projection of the raster.
 raster2pgsql -s 910001 -t 1073x1 -R -C /tmp/ds.maxt.bin test_raster | psql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2586#comment:1>
