[postgis-tickets] [PostGIS] #2588: GeometryCollection constructor parse defect for sub geometries (POINTM, POLYGONM, ...) of GEOMETRYCOLLECTIONM
PostGIS trac at osgeo.org
Sun Jan 5 12:24:58 PST 2014
(POINTM,POLYGONM,...) of GEOMETRYCOLLECTIONM
 Reporter:  bergun                                    |       Owner:  delawen
     Type:  defect                                    |      Status:  new
 Priority:  medium                                    |   Milestone:  PostGIS 2.2.0
Component:  java                                      |     Version:  trunk
 Keywords:  GEOMETRYCOLLECTIONM jdbc POINTM POLYGONM  |
Comment(by bergun):
 Our tests can be viewed from https://github.com/datanucleus/tests
 repository and jdo/geospatial project.
 PgGeometryMappingTest.java
 PgGeometryMySQLTest.java
 PgGeometryPostGISExtMappingTest.java
 PgGeometrySpatialHelperTest.java
 PgGeometrySpatialTest.java
 There are 205 tests for Mysql/Mariadb and around 230 tests for Postgresql
 db. There are 2D, 3D and M geometries tests if u have look at the test
 classes. All of the test cases I have tested to be ok after updating the
 GeometryCollection class.
 I didnt actually understand why the second signature was added to the
 below method
 public void outerWKT(StringBuffer sb, boolean putM)
 because even putM is declared as false or true inside the method there is
 check for if Geometry haveM and 2dimensional.
 if (putM && haveMeasure && dimension == 2) {
 on line 263 Geometry.class
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2588#comment:3>
