[postgis-tickets] [PostGIS] #2564: Implement the inverse of the ST_AsLatLonText function
    trac at osgeo.org
    Mon Jan  6 16:56:49 PST 2014
 Reporter:  andrewxhill  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Changes (by dbaston):
 * cc: dbaston (added)
Comment:
 This is something I've thought would be useful too, and I'd be happy to
 put together a patch for consideration.
 I see a few directions this could take:
 1) Input text must match some very rigid format (no risk of
 misinterpretation) or returns error.  Somewhat reduces the utility of
 function, which is when you have coordinates that you don't feel like
 parsing yourself.
 2) Input text must match looser format (some risk of misinterpretation of
 strange input) returns error if anything really weird.  By loose I mean
 accepting up to 3 valid numbers divided by non-numbers and assuming they
 represent D, M, S.
 3) Input text must match user-supplied format string.
 ST_AsLatLonText($$31°55'12.000"N$$, $$DD°MM'SS.SSS"X$$) for example.
 Any thoughts?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2564#comment:2>
