[postgis-tickets] [PostGIS] #2564: Implement the inverse of the ST_AsLatLonText function
PostGIS trac at osgeo.org
Tue Jan 7 02:49:36 PST 2014
 Reporter:  andrewxhill  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by strk):
 I think a format string is the way to go, including a format character to
 obtain the "looser" behavior, to make every case supported. The "loose
 format string" would be the default.
 Any output from ST_AsLatLonText, with a given format string, should be
 interpreted to result in its input when passed with the same format string
 to ST_FromLatLonText. The output from ST_AsLatLonText with no format
 string should be interpreted to result in its input when no format string
 is used in the ST_FromLatLonText function.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2564#comment:4>
