[postgis-tickets] [PostGIS] #2605: armel: _ST_Covers() returns true for point in hole
PostGIS trac at osgeo.org
Tue Jan 7 14:29:37 PST 2014
 Reporter:  mwanner  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by mwanner):
 The corresponding _ST_CoveredBy() call fails in the same way, which is the
 reason for test 'tickets' failing on #2084. The following is a simplified
 version that mistakenly returns true:
 test=# SELECT _ST_CoveredBy('POINT(13 25)'::geometry, 'POLYGON((9 28, 16
 29, 16 23, 10 23, 9 28),(15 25, 13 27, 11 24, 15 25))'::geometry);
  _st_coveredby
  t
 (1 row)
 However, I guess this runs through the same code path.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2605#comment:1>
