[postgis-tickets] [PostGIS] #2607: [raster] Unable to open more than 1024 out-db files in a single connection
PostGIS trac at osgeo.org
Tue Jan 7 18:26:30 PST 2014
 Reporter:  dustymugs  |       Owner:  dustymugs
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  PostGIS 2.0.6
Component:  raster     |     Version:  2.0.x
 Keywords:             |
 On a large query spanning every day of many years, I get the following
 error:
 rt_band_load_offline_data: Cannot open offline raster: SOME_RASTER_FILE
 In the PostgreSQL logs...
 ERROR 4: `SOME_RASTER_FILE' not recognised as a supported file format.
 I know these files are all valid rasters (as per GDAL).
 Pruning the query to access <= 1024 raster files permits the query to
 complete. This does have the assumption that the connection is new and
 there-fore the process has no open out-db raster files.
 Googling (can't find link) indicated that GDAL limits the number of open
 files to 1024. Just in case this was not true, I did alter the soft and
 hard nofile limits of the system for the postgres user with no luck.
 The immediate solution is to not use GDALOpenShared for opening out-db
 rasters but instead GDALOpen. A better solution is keep track of the out-
 db rasters opened in the process and then close those as needed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2607>
