[postgis-tickets] [PostGIS] #2564: Implement the inverse of the ST_AsLatLonText function
PostGIS trac at osgeo.org
Sat Jan 11 15:33:38 PST 2014
 Reporter:  andrewxhill  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by dbaston):
 Interesting.
 I was getting hung up on how to write a format string that could handle
 undelimited versions of both
 99°59'59.999" and 100°00'00.000" ?
 It seems like you'd have to go with
 DMMSS.SSS : you specify the number of digits for minutes and seconds, and
 everything leftover on the left is taken to be degrees?  Minutes and
 seconds would have to be left-padded with zeros for correct
 interpretation...
 Of course, with input that rigid, it would be pretty easy to use a
 substring function to build the geometry too.  Just thinking out loud...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2564#comment:7>
