[postgis-tickets] [PostGIS] #2616: Reduce geometry::text conversion in topology functions
PostGIS trac at osgeo.org
Mon Jan 27 02:13:22 PST 2014
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.1.2
Component:  topology     |     Version:  2.1.x
 Keywords:               |
 A single call to TopoGeo_addPolygon, against an _empty_ topology, results
 in 24 calls to the text(geometry) function. The second most-called
 function is "postgis_type_name" (6 calls).
 The time spent in geometry::text is really not much (16th most expensive
 function) but still it sounds like something worth cleaning up.
 There are 2 tasks:
  1. Avoid converting the geometry multiple times within a single function
  2. Use EXECUTE .. USING expression (to avoid conversion to text as a
 whole)
 If someone is looking for an easy task to get used to the code, this is
 the perfect task :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2616>
