[postgis-tickets] [PostGIS] #2396: regression tests fail on big-endian architectures (was: liblwgeom CUnit and PostgreSQL tests fail on big-endian architectures.)
PostGIS trac at osgeo.org
Wed Jan 29 01:16:24 PST 2014
  Reporter:  mnencia  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.1.1
 Component:  postgis  |     Version:  2.1.x
Resolution:           |    Keywords:
Changes (by mwanner):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 It turned out there are several other big-endian related issues remaining
 in 2.1.1. For that version to pass tests successfully on all Debian-
 supported architectures, I also had to disable a few more tests that
 checked against a little-endian serialization of data.
 While I agree that's not a good way to make tests pass, it's the only
 option I saw ATM. Especially given that there seem to be a few other
 places doing the same, I guess a better solution isn't available, now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:37>
