[postgis-tickets] [PostGIS] #2625: pom.xml enhancments necessary
PostGIS trac at osgeo.org
Fri Jan 31 04:33:07 PST 2014
 Reporter:  bergun       |       Owner:  bergun
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.2
Component:  java         |     Version:  2.1.x
 Keywords:               |
 As the below Warnings indicate we need to update pom.xml to be compatible
 with future versions of maven. I will fix this for jdbc and jts parser
 projetcs.
 [WARNING] Some problems were encountered while building the effective
 model for org.postgis:postgis-jdbc:jar:2.1.0SVN
 [WARNING] 'version' contains an expression but should be a constant. @
 jdbc:${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION},
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 8, column 11
 [WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins
 :maven-javadoc-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 127, column 12
 :maven-dependency-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 130, column 12
 :maven-project-info-reports-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 133, column 12
 :maven-surefire-report-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 136, column 12
 [WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo
 :findbugs-maven-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 139, column 12
 :javancss-maven-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 143, column 12
 :jdepend-maven-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 147, column 12
 [WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:jxr-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 151, column 12
 :taglist-maven-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 155, column 12
 :versions-maven-plugin is missing. @ org.postgis:postgis-
 /storage/software/postgis/postgis/java/jdbc/pom.xml, line 159, column 12
 [WARNING]
 [WARNING] It is highly recommended to fix these problems because they
 threaten the stability of your build.
 [WARNING]
 [WARNING] For this reason, future Maven versions might no longer support
 building such malformed projects.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2625>
