[postgis-tickets] [PostGIS] #2628: loader_generate_script output is buggy
PostGIS trac at osgeo.org
Fri Jan 31 08:33:27 PST 2014
 Reporter:  beland   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.2
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 One of the steps in setting up the TIGER geocoder is to run, for example:
 SELECT loader_generate_script(ARRAY['MA'], 'sh') AS result;
 The resulting script is buggy: it does not respect several of the
 configuration steps at the top, and some lines refer to non-existent
 files. I'm attaching a version with suggested fixes.
 I am running postgis2_93-2.1.1-1.rhel6.x86_64 on CentOS 6.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2628>
