[postgis-tickets] [PostGIS] #2333: Can't compile under mingw64 (neither mingw64 or mingw32)
PostGIS trac at osgeo.org
Mon Jun 2 16:30:04 PDT 2014
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
Comment(by robe):
 Made some big progress.  Got sfcgal 1.0.4 compiling with PostGIS 2.2 dev.
 Unfortunately my make check is not quite working.
 However I was able to install in my 9.4beta1 w32 edb and do this:
 SELECT ST_AsText(ST_Extrude(ST_Buffer(ST_Point(1,2),10),3,4,5));
 and get a poiyhedralsurface z back.
 I have to retrace my steps since I ran into a lot of issues.
 For example I had to fiddle with the SFCGAL cmake output to get mpfr
 listed before gmp as documented in FAQ 5:
 http://www.mpfr.org/faq.html#undef_ref2
 I'll retrace my steps to confirm that was what I did to fix it.
 Also the sfcgal-config file has the generated .dll being looked for in the
 lib folder (though the .dll.a was in lib), but CMake had installed it in
 the bin folder, so had to copy it to lib to be found by PostGIS.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2333#comment:9>
