[postgis-tickets] [PostGIS] #2755: 4 regression failures for sfcgal
PostGIS trac at osgeo.org
Wed Jun 4 21:51:34 PDT 2014
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal   |     Version:  trunk
 Keywords:           |
 Running sfcgal on my 9.4 beta1 windows 32-bit, I see 4 errors:
 regress_sfcgal .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.4w32/test_95_diff)
 sfcgal/empty .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.4w32/test_96_diff)
 sfcgal/regress_ogc .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.4w32/test_101_diff)
 sfcgal/tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.4w32/test_103_diff)
 my regress output is also a bit of a mess on screen, but I thin that is
 probably a different issue.
 I've attached the related files.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2755>
