[postgis-tickets] [PostGIS] #2757: postgis-2.1.3 compile failed with json-c-0.12
PostGIS trac at osgeo.org
Thu Jun 5 03:56:47 PDT 2014
 Reporter:  declanqian  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
 when I try to compile the PostGIS 2.13 with json-c-0.12, it keep saying
 that: can't find json dev file... and it end up with no json support. When
 I was trying to build it with json-c-0.9. it works fine. Here is my
 ./configure:
 ./configure --with-
 pgconfig=/alidata1/Applications/PostgreSQL/9.3.4/bin/pg_config --with-
 gdalconfig=/alidata1/Applications/gdal/1.11.0/bin/gdal-config --with-
 geosconfig=/alidata1/Applications/geos/3.4.2/bin/geos-config --with-
 projdir=/alidata1/Applications/proj/4.8.0/ --with-
 libiconv=/alidata1/Applications/libiconv/1.14/ --with-
 jsondir=/alidata1/Applications/json-c/0.9 --with-raster --with-topology
 --with-gettext=no --with-sfcgal=/alidata1/bin/
 I guess it maybe a bug, and it should be pointed out on the somewhere, may
 be the docs or the webpage.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2757>
