[postgis-tickets] [PostGIS] #2758: ST_Intersects missing rows
PostGIS trac at osgeo.org
Sat Jun 7 05:44:39 PDT 2014
  Reporter:  schmiddy  |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:
 Component:  postgis   |     Version:  1.5.X
Resolution:  invalid   |    Keywords:  ST_Intersects
Changes (by schmiddy):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Oh geez, pramsey is dead on! A quick check like:
 SELECT ST_IsValid(poly) FROM mytest;
 gives complaints like:
 NOTICE:  Too few points in geometry component at or near point
 -97.967399999999998 26.166599999999999
 And robe: yes, that the version string I posted earlier is what SELECT
 postgis_full_version() tells me, namely:
  POSTGIS="1.5.3" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012"
 LIBXML="2.7.8" USE_STATS (procs from 1.5 r5385 need upgrade)
 Marking ticket 'invalid' per pramsey's comment.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2758#comment:3>
