[postgis-tickets] [PostGIS] #2760: geocoder producing erronous results
PostGIS trac at osgeo.org
Tue Jun 17 12:52:33 PDT 2014
 Reporter:  infinityedge  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:
Component:  postgis       |     Version:  2.1.x
 Keywords:  geocoder      |
Comment(by infinityedge):
 I reinstalled the geocoder by cascade dropping the tiger schema,
 reinstalling the geocoder extension, exporting loader scripts (edited
 versions attached), then running those scripts.
 Geocoding is still useless:
 california=# select (geocode('One Shields Avenue Davis, CA 95616',100));
                                        geocode
 ("(,,,,,,Davis,CA,95616,t)",0101000020AD100000E14FB563246F5EC0FDCC369010474340,100)
 (1 row)
 california=# select (geocode('805 Russell Blvd, Davis, CA 95616',100));
                                        geocode
 (1 row)
 california=# select (geocode('30 LA PATERA CT., CAMARILLO, CA 9301',1));
                                         geocode
 ("(,,,,,,Camarillo,CA,9301,t)",0101000020AD10000094427E4216C25DC040DA73608C1C4140,100)
 (1 row)
 california=# select (geocode('280 SKYWAY DRIVE, CAMARILLO, CA 93010',1));
                                          geocode
 ("(,,,,,,Camarillo,CA,93010,t)",0101000020AD10000094427E4216C25DC040DA73608C1C4140,100)
 (1 row)
 It didn't used to be this bad. The prior version geocoded the same list
 I'm working with just fine. What has changed in the geocoder, and is there
 any way to work around it?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2760#comment:1>
