[postgis-tickets] [PostGIS] #2737: [PATCH] Upgrade of spatial_ref_sys.sql to EPSG v8.4
PostGIS trac at osgeo.org
Tue Jun 17 13:38:54 PDT 2014
  Reporter:  rouault  |       Owner:  robe
      Type:  patch    |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  history
Comment(by robe):
 pramsey so back to DATUM times?  I'm sold by Even't comment
 ""+datum=foo" is more expressive however and enables GRASS to propose a
 U.I where users can select a range of possible datum shifts when several
 can apply"
 Though I guess that means we are more reliant on datum shift files which
 could be different for some reason so harder to debug.
 I compared what EvenR just attached and down to 343 differences from 713
 before.   A lot of the differences seem to be because our file is a
 mishmush of towgs84 expansion and datum (not sure how that happened)  so
 guess I have to do a 3 way compare and then compare to our logs what's
 left.
 The 1000 someodd additional that are in Even's file, I'm just going to
 blindly accept :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2737#comment:15>
