[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Thu Jun 19 06:13:45 PDT 2014
st_countagg(raster,integer,boolean,double precision) does not exist
  Reporter:  robe                   |       Owner:  dustymugs
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Comment(by strk):
 Robe did you file that other ticket ?
 I'm still stuck with updating an extension from '2.2.0dev r12625'  to
 current master:
 ERROR:  function st_countagg(raster, integer, boolean, double precision)
 does not exist
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:18>
