[postgis-tickets] [PostGIS] #2765: Unable to find driver ESRI to unload from GDAL_SKIP environment variable
PostGIS trac at osgeo.org
Thu Jun 19 07:50:22 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by dustymugs):
 We only use short names. The ESRI is really "ESRI Shapefile" which IS the
 short name for the OGR shapefile driver. Are you specifying "ESRI
 Shapefile" in postgis.gdal_enabled_drivers GUC? For 2.0, we only look at
 those drivers with a raster component so no vector drivers are possible.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2765#comment:2>
