[postgis-tickets] [PostGIS] #2771: GDAL-dependent memory size of rasters ?
PostGIS trac at osgeo.org
Fri Jun 20 07:42:11 PDT 2014
 Reporter:  strk     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Running "make check" locally works fine, but Travis fails on the
 ST_MemSize calls:
 https://travis-ci.org/postgis/postgis/builds/28040817
 Can it be size of rasters differ based on GDAL version ?
 See #2770 for the ticket introducing ST_MemSize
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2771>
