[postgis-tickets] [PostGIS] #2771: GDAL-dependent memory size of rasters ?
PostGIS trac at osgeo.org
Fri Jun 20 08:36:11 PDT 2014
 Reporter:  strk     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I'm trying to run the query so to subtract the length of band paths, but I
 stumbled upon what looks like being another bug: ST_BandPath returning
 random strings.
 This query, put in raster/test/regress/rt_utiligy.sql right before my new
 test ("ms1"):
 SELECT 'BandPath', rid, ST_BandPath(rast,1) from raster_outdb_template;
 Gives this output:
     band 1 of pixtype 8BUI is out-db with NODATA value of 255
      band 2 of pixtype 8BUI is in-db with NODATA value of 0
 +BandPath|1|^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^S^B
 +BandPath|2|^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?~^W^B
 +BandPath|3|
 +BandPath|4|^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?^?~^W^B
  ms1|64
 Is there any test for ST_BandPath ?
 I guess this should go in another ticket...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2771#comment:7>
