[postgis-tickets] [PostGIS] #2776: [raster] rt_utility regress failure on debbie against GDAL Trunk
PostGIS trac at osgeo.org
Mon Jun 23 07:33:37 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 Not sure if this is a change in GDAL or PostGIS, but getting regression
 failure as of around 6/20/2014
 PostgreSQL 9.2.4 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
   Postgis 2.2.0dev - r12630 - 2014-06-20 21:25:51
   scripts 2.2.0dev r12630
   raster scripts 2.2.0dev r12630
   GEOS: 3.4.3dev-CAPI-1.8.3 r3982
   PROJ: Rel. 4.7.1, 23 September 2009
   GDAL: GDAL 2.0.0dev, released 2014/04/16
 Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_tile .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  rt_metadata .. ok
  rt_rastertoworldcoord .. ok
  rt_worldtorastercoord .. ok
  rt_convexhull .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_pixelaspolygons .. ok
  rt_pixelaspoints .. ok
  rt_pixelascentroids .. ok
  rt_setvalues_array .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  rt_neighborhood .. ok
  rt_nearestvalue .. ok
  rt_pixelofvalue .. ok
  rt_polygon .. ok
  rt_utility .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_42_diff)
 --- rt_utility_expected 2014-06-20 14:25:12.000000000 -0700
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_42_out
 2014-06-20 14:28:56.000000000 -0700
 @@ -52,7 +52,7 @@
      band 1 of pixtype 8BUI is out-db with NODATA value of 255
      band 2 of pixtype 8BUI is in-db with NODATA value of 0
  ms1|64
 -ms2|280
 -ms2|280
 -ms2|8240
 -ms2|8240
 +ms2|400
 +ms2|400
 +ms2|8280
 +ms2|8280
  rt_fromgdalraster .. ok
  rt_asgdalraster .. ok
  rt_astiff .. ok
  rt_asjpeg .. ok
  rt_aspng .. ok
  rt_reclass .. ok
  rt_gdalwarp .. ok
  rt_asraster .. ok
  rt_dumpvalues .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  rt_intersection .. ok
  rt_clip .. ok
  rt_mapalgebra .. ok
  rt_mapalgebra_expr .. ok
  rt_mapalgebra_mask .. ok
  rt_union .. ok
  rt_invdistweight4ma .. ok
  rt_4ma .. ok
  rt_setvalues_geomval .. ok
  rt_elevation_functions .. ok
  rt_colormap .. ok
  rt_gist_relationships .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  rt_geos_relationships .. ok
  rt_iscoveragetile .. ok
  bug_test_car5 .. ok
  permitted_gdal_drivers .. ok
  tickets .. ok
  loader/Basic .... ok
  loader/BasicCopy .... ok
  loader/BasicFilename .... ok
  loader/BasicOutDB .... ok
  loader/Tiled10x10 .... ok
  loader/Tiled10x10Copy .... ok
  loader/Tiled8x8 .... ok
  clean .. ok
  uninstall .
 /var/lib/jenkins/workspace/postgis/gdal_regress/branches/2.2/regress/00
 -regress-install/share/contrib/postgis/uninstall_rtpostgis.sql
 -regress-install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4061)
 Run tests: 85
 Failed: 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2776>
