[postgis-tickets] [PostGIS] #2777: Huge literal in enforce_max_extent_rast check constraint
PostGIS trac at osgeo.org
Mon Jun 23 10:36:13 PDT 2014
 Reporter:  strk    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:
Component:  raster  |     Version:  trunk
 Keywords:          |
Comment(by dustymugs):
 Depends on your use case. I use it ensure continous streams of
 meteorological data per variable is consistent over time. For static
 raster's, it is of less value.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777#comment:3>
