[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Tue Jun 24 08:35:14 PDT 2014
"postgis.backend"
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by strk):
 The r12351 commit was reverted with r12642, and upgrades in new sessions
 still work fine.
 I suggest to try at implementing the "replace-if-exists" policy for the
 GUC, so that even upgrades in sessions with pre-loaded old postgis library
 will work.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:35>
