[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Tue Jun 24 12:21:04 PDT 2014
"postgis.backend"
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by vmo):
 strk, this patch improves the solution in the case more than one lib is
 used by a module. A hash is used as a set and every /'$libdir\/[^']+'/ is
 loaded.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:36>
