[postgis-tickets] [PostGIS] #2723: failure to build against external json-c 0.12
PostGIS trac at osgeo.org
Tue Jun 24 15:01:08 PDT 2014
 Reporter:  landry   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.4
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by pramsey):
 I've applied a patch to trunk that works for me, and hopefully others,
 trying to support json-c 12, which has removed some symbols and re-located
 where the install is.
 r12647
 In terms of supporting older versions, I'll have to get the source and see
 what's changed. I did check back to 0.10 and this fix should work back to
 there.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2723#comment:5>
