[postgis-tickets] [PostGIS] #2785: sfcgal-config check should be constrained to accept only file
PostGIS trac at osgeo.org
Wed Jun 25 12:53:15 PDT 2014
 Reporter:  giohappy         |       Owner:  colivier
     Type:  defect           |      Status:  new
 Priority:  medium           |   Milestone:
Component:  sfcgal           |     Version:  trunk
 Keywords:  configure,build  |
 As reported in [1] if sfcgal-config is given a folder path and not a file
 path, configuration goes on but sets wrong variables for SFCGAL linking.
 Probably line 27 of configure.ac should be changed to:
 if [ -x "$SFCGAL_CONFIG" ] && [ -f "$SFCGAL_CONFIG" ]; then
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2785>
